#11 | |
Liked 759 Times in 379 Posts
#12 |
Liked 586 Times in 162 Posts
If memory serves correct you are right. It was a way to help soften the backlash from the Modified Eliminator elimination too. Super Gas was a door car class where some of the Anglias Monzas and Vegas wound up and Super Comp found some of the old Econo dragsters and Altered wound up. Throttle Stops weren’t invented yet and a lot of adding weight and pedal stops were used to hit the number
. Modifiedcars also had Comp Eliminator for some to fall into and Super Stock for some. So when people say bring back Modified Eliminator I get confused. It’s still there just backyard built tunnel rammed small blocks with 5 speeds are no longer backyard built. Take a look at what Comp is today with the Super Modified classes and Altered classes and those would have been a lot of your MP cars today. Sorry. Different rant. My mind wanders. |
#13 |
Nothing is going backwards, the 90s are long gone no mind the 70s! We don't do dry hops anymore and there's no bleach in the water box. Typewriters, VHS/VCRs and princess phones are never coming back either.
![]() Last edited by 1320racer; 11-30-2023 at 08:11 AM. |
#14 |
Liked 36 Times in 26 Posts
Seems to me this 90 stuff should be on the 90 columns and not super, stock column. Someone who can run two seconds under the index and then wants them lowered, should look at what they are doing. I believe you should start on something that is a challenge, instead of complaining...
#15 |
I ain't complaining, we've done every well in S/C the past 5 years and you don't make the rules here.
#16 | |
Liked 627 Times in 156 Posts
Pete Lanciers PAL Automotive Racing Stock 7801 |
#17 |
Liked 66 Times in 29 Posts
#18 |
this isn't about you/us, we are sportsman/class racers not spectators, that wouldn't be there if not for competing at the event.
#19 |
Liked 393 Times in 153 Posts
My “opinion” is that, if I built a 190mph 9.90 car so I can always be the chaser… if you lower the index I’ll still run 190 but at 8.80. Or, I’ll build a motor to run 200@8.90…. And zero has changed. Still a 2 second delay as I ensure I am the fastest and always chase.
#20 |
My opinion is that it's ridiculous that .90 cars today, specially S/C and S/G are still indexed as they were over 3 decades ago and ET slower than some stockers and all the FSS cars.
