Liked 251 Times in 51 Posts
If a car is in the guide, it's a combo.....to be developed. Doesn't have to be a 8 second bomb.
Kudos to someone who will take an oddball combination (slant 6 for an example, Mike Jeffries) and make it run, and run well. And go rounds. Keep it up Billy, you are an innovator!! #5458 Curt Rees
Curt Rees 5457 SS |
Liked 7,909 Times in 1,754 Posts
I've been spending some of my spare time moving some things around in the frontend of the Cavalier. The alignment is one of the things that I have neglected on this car simply because I've been keeping myself busy with other things. No excuses.
The car was always a bit "darty"(?) for lack of a better word in high gear but it always stopped straight and isn't at any point a "handful". I'm setting the camber at zero for lack of a better place to start and assuming that trying to keep the slicks "flat" with the track can't be a bad thing. There is no real caster adjustment on these cars so I'm "slotting" my upper strut plate mounting holes to get myself some positive caster. I'll then be setting my toe and I'm thinking to start at about 3/16 or 1/8 out remembering that FWD cars toe IN under acceleration not out like a RWD car. Then just the long wait for Spring!
We had the Monte set slightly negative camber. As the front rose , it started to go positive. Adjustable struts slowed down this motion to where it didn't get to high , or too bad.
(Yes, the front rises, as it reacts to engine torque and rotation.) 1/8th out sounds about right, as the tires try to look at each other, from the torque reaction.
Liked 354 Times in 120 Posts
We slotted the holes in the balljoints and used 3/8 grade 8 bolts to get caster. Never had a problem on dirt. Tom
Tom Meyer 5240 SS Stock ??? |
Liked 405 Times in 158 Posts
I was going to say "how about an update Billy...then I saw you said you're waiting for spring too....I keep thinking all Americans have Texas weather 24/7/365, LOL!!
How about, "any more progress"? |
Ya know, it sure would be nice if the NHRA would add a couple of FWD classes! These 3 lb. weight breaks make it almost impossible to change classes. Since they changed the breaks last year, I've been running CF/S mainly because that's really the only practical class that I can run. The way the breaks are now, I would have to ADD 420 lbs.(!?!) to go to DF/S or remove 420 lbs.(not possible) to go to BF/S. Any ideas?
Liked 192 Times in 44 Posts
Any updates on the Cavalier?
facebook.com/racersnewsnetwork |
