Old 08-18-2023, 12:03 PM   #1
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Roller Cams in Stock Eliminator?
Originally Posted by john ancona View Post
Suggestions are what is needed for sure ,I am not going to speak for Terry or any others,
I have said in the past on here the reasons as to why a change is needed , for my self I have been racing NHRA for 50 plus years now like many of my friends have, I still seem to be hearing the same story about flattened cams ,and ruined lifters form many
along with engines that have been ruined , so it's not just two of us supporting that something be done
Not calling you out, but John you don't speak for me either.
JMHO...Keep Stock...Stock!
While we cannot undo past changes... we do have the ability to stop future changes!
As far as lifters are concerned, we toasted a SS engine first rnd of qualifying at Denver. We had a lifter go bad and take out a camshaft. The full extent of the damage has yet to be determined. At best it is a lifter, a reground cam, and a pushrod. At worst...we shall see.
This was a $$$$ lifter. **** Happens. We have not had a stocker lifter go bad since 2007 (knock, knock, knock...knock on wood) and that was a Schubeck lifter which exploded on startup. We have now had two roller lifters go bad in the last 5 years. If your having lifter issues, then fix the issue...don't change the rules! We found our issue for the first SS failure...it was an issue put in place by a now closed engine builder in the Houston, Texas area. The current issue appears to me to be a bearing failure. we will determine whether it is a material failure, or if the failure was caused by some other issue within the engine. Either way, I have complete confidence any future failure will not be for the same reason.
I do not believe in the concept of "One person ****s their pants...everybody wears diapers!"
Bill Grubbs is offline   Reply With Quote
Old 08-18-2023, 12:12 PM   #2
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
We need Bubskis input on this rule change proposal!!!
Duane Hoven
1342 SS/GT
1347 is online now   Reply With Quote
Old 08-18-2023, 12:27 PM   #3
Billy Nees
Liked 7,777 Times in 1,742 Posts
Bill! Why do you have to keep bringing that up! I TOLD you it was an accident!
Billy Nees 1188 STK, SS
Old 08-18-2023, 01:19 PM   #4
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
When a roller lifter that has roller and not a bushing breaks it can get very expensive. Also rollers increase the lifter bore side load and some old blocks may have a problem with breaking lifter bores.
Stan
Old 08-18-2023, 01:39 PM   #5
melvin wellman
Liked 2 Times in 2 Posts
I know this is no help. But back around 1981 McCandless was selling the cam dynamics cheater cam for 25 bucks. I got one and some 40 dollar lifters from the local auto parts store. This was in a 440 and it really woke that thing up. I know things need to evolve, but that was a fun experience with no drawbacks. I ran that thing for a long time and never had any wear issues. Like I said, no help, just seemed a bit simpler at the time.
melvin wellman is offline   Reply With Quote
Old 08-18-2023, 02:00 PM   #6
Doug Hoven
Liked 867 Times in 165 Posts
I know this won’t happen either, but what about putting some sort of valve spring pressure rule into place? Maybe if one didn’t have to, or wasn’t allowed to, run so much spring pressure to keep their valvetrain under control with a radical cam lobe , they won’t wear out camshafts and lifters every other season.
1189 F/SA
Defunzalo Racing Enterprises
Old 08-18-2023, 02:49 PM   #7
Dan Bennett
Liked 595 Times in 136 Posts
Makes total sense. But the problem is that people would have to be paid to check that. And I'm pretty sure that golfing fees have gone up like everything else so the suits are not gonna go for something like that.
Dan Bennett is offline   Reply With Quote
Old 08-18-2023, 03:48 PM   #8
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
My billet cam $710 from bullet, not $1200.
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 08-18-2023, 01:35 PM   #9
john ancona
john ancona's Avatar
Liked 186 Times in 57 Posts
Some how you ,and others think I am speaking for all of Stock Eliminator when in fact as I said on the site many times there are those of us in my circle of friends of witch you and others last time I checked are not included , look I run stock ,and super stock
so there is no need to say I am trying to change Stock as I am in the crowed that voiced my opinion many times over the years right to NHRA at Pomona in person with many others about all the changes over many years with that said ,I have yet to hear any body say oh we will remove any of the changes on my car up to this point ,but there are those on here that are quick to say keep Stock Stock that have all the changes on there cars
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
