Old 07-03-2023, 12:05 PM   #1
KRatcliff
Liked 524 Times in 141 Posts
Default Re: Hemi splined input shaft wanted
Originally Posted by Paul Merolla View Post
I gave up looking for an input and just had a machine shop turn down a hunk of bar stock...you don't need the splines. Been using it for 10 years now. Just a thought.
I think that is the route I may go.
KRatcliff is offline   Reply With Quote
Old 07-03-2023, 01:23 PM   #2
older racer
Liked 66 Times in 26 Posts
i did same, used aluminum shafting, no splines works great and cheap.
older racer is offline   Reply With Quote
Old 07-05-2023, 11:37 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
If you are having problems with alignment with the plastic just get it close and put someone in the car and release the clutch as you are putting the trans into the splines. That floats the disc and it should self align, esp if you have the trans on slides or dowels.
Adger Smith (Former SS)
Old 07-05-2023, 01:23 PM   #4
KRatcliff
That is what I generally do when I am having trouble, but my alpaca isn't always available and I have to do it alone.
Search this Thread:
Advanced Search
