Old 06-17-2023, 08:14 AM   #1
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: SFI flexplate mandatory in all v8s Jan 2024
Originally Posted by MikeMoller View Post
Like to know how they will be checking that-they don’t check anything these days
They'll check it when it's laying on track or out from under the car. Then you will get a nice letter and a fine.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 06-17-2023, 05:19 PM   #2
Jim Bailey
Liked 584 Times in 94 Posts
Never had any problems with any SFI certified Mopar Flex Plates "UNTIL" I started to two step. We're our own worst enemy. If you two step, the flex plate must become a part of your service routine. Just saying .........
Jim Bailey is offline   Reply With Quote
Old 06-18-2023, 12:03 AM   #3
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Did it crack or explode.
Old 06-18-2023, 08:17 AM   #4
4543
Liked 646 Times in 140 Posts
I’m not sure if it’s the 7000 rpm or the converter hitting at 5800 instead of the 4400 people used to use! I think the converter hit stresses the flex plate more than going down the track but it could crack at the hit and come apart down track. The stock GM flex plate that I saw has the ring gear only welded on one side. The certified appears to be welded on both sides of the ring gear and possibly more welds. Both of mine are certified but have been in my cards for years. I’m thinking I’m going to replace them. Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
Old 06-18-2023, 08:23 AM   #5
Billy Nees
Liked 7,768 Times in 1,741 Posts
Now just to be "fair", this ruling is going to apply to all V8 bracket cars also right?
Billy Nees 1188 STK, SS
Old 06-18-2023, 09:30 AM   #6
Chevy55
Banned
Liked 179 Times in 89 Posts
2023 NHRA RULE AMENDMENTS
Beginning January 1, 2024, SFI 29.1 flexplate mandatory on all V-8 vehicles. Any car running quicker than 9.99, SFI 29.1 automatic transmission flexplate and SFI 30.1 flexplate shield mandatory. See General Regulations 2:12, 2:14.
Chevy55 is offline   Reply With Quote
Old 06-18-2023, 11:20 AM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Having repaired several racers cars after a flexplate explosion I cannot understand why anyone would be against this rule which should have been in place years ago.
I've seen headers sliced off, frame rails cut in half and floors with shrapnel sticking thru within inches of the drivers feet. . Not to mention the possibility of severe injury to track personell or even your crew menbers.
Jim Bailey is correct . the 2 step is well known for causing other issues like broken oil pumps and pickups..
Old 06-18-2023, 11:49 AM   #8
Yes..Okay.
So how does that apply to U/SA 273 Mopars?
Old 06-18-2023, 12:00 PM   #9
Billy Nees
This ruling only applies to S/SS cars and I'm not saying that in most cases it isn't a good idea BUT it doesn't apply to a low 10 second bracket car so why should it apply to a "U/SA 273 Mopar" or a P/SA 301 Pontiac that rarely if ever sees over 6 grand?
And where am I supposed to find this 301 Pontiac SFI approved flex plate?
Maybe a re-think and a change to 11.99 or quicker might be prudent?
Old 06-18-2023, 12:02 PM   #10
Charlie Yannetti
Liked 192 Times in 83 Posts
This could be the question of the day.. especially that I hear more and more people saying that the tracks that they race at, don't require this, or don't require that..
Charlie Yannetti is offline   Reply With Quote
