Old 06-17-2023, 08:06 AM   #1
Liked 10,693 Times in 2,227 Posts
Default Re: SFI flexplate mandatory in all v8s Jan 2024
I don’t think the ring gear knows any difference if it’s being spun to 7000rpm by a BBC, SB2, SBC, V6, or a 151.
Old 06-18-2023, 01:01 PM   #2
SSDiv6
Liked 1,580 Times in 582 Posts
There are many variables applicable to flexplates.
Lots of considerations such as horsepower, RPM range, size/diameter, one-piece or two-piece design must be considered.
The SFI 29.1/29.2 test entails the flexplate turning 12000 RPM's for one hour. However, the test equipment does not simulate the effects of heat, engine load, flex, having a torque converter attached to it and transmitting the horsepower and torque to the drive line. When applicable, add a car with a transbrake and/or two-steps.
I consider both the SFI harmonic balancer, flexplate or flywheel/cluth a safety item. In the early days of Modified Eliminator, with heavy flywheels and OEM flexplate, saw them come through the floor, cut fuel and brake lines many times causing injury and damage.
Although high in cost, my preference are the Reactor Products (without the inertia ring) and Meziere flexplates. They have a great selection of configurations and weight for different end applications.
Other great options are the ATI, TCI billet line and ATF
Old 06-18-2023, 02:06 PM   #3
dragracerray
dragracerray's Avatar
Liked 208 Times in 89 Posts
The SFI 29.1/29.2 test entails the flexplate turning 12000 RPM's for one hour. However, the test equipment does not simulate the effects of heat, engine load, flex, having a torque converter attached to it and transmitting the horsepower and torque to the drive line. When applicable, add a car with a transbrake and/or rev limiter.
SS,
Two Steps cannot be good for a flexplate either. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 06-18-2023, 02:23 PM   #4
SSDiv6
Originally Posted by dragracerray View Post
SS,
Corrected...meant two-steps, not rev-limiter.
