Liked 18 Times in 13 Posts
I used The Wheel from JW transmissions on my powerglide for years. I guess some people like a lighter weight but it was consistent and heavy duty, I trusted it 100%.
Liked 66 Times in 31 Posts
Mark, you don't think it might have more to do with RPM rather than E.T.
Liked 5,124 Times in 1,953 Posts
It might but would be hard to regulate that in an equitable manor...Re: Eco-Tec 4
Liked 10,714 Times in 2,230 Posts
I don’t think the ring gear knows any difference if it’s being spun to 7000rpm by a BBC, SB2, SBC, V6, or a 151.
#5 | |
Liked 1,583 Times in 582 Posts
Lots of considerations such as horsepower, RPM range, size/diameter, one-piece or two-piece design must be considered. The SFI 29.1/29.2 test entails the flexplate turning 12000 RPM's for one hour. However, the test equipment does not simulate the effects of heat, engine load, flex, having a torque converter attached to it and transmitting the horsepower and torque to the drive line. When applicable, add a car with a transbrake and/or two-steps. I consider both the SFI harmonic balancer, flexplate or flywheel/cluth a safety item. In the early days of Modified Eliminator, with heavy flywheels and OEM flexplate, saw them come through the floor, cut fuel and brake lines many times causing injury and damage. Although high in cost, my preference are the Reactor Products (without the inertia ring) and Meziere flexplates. They have a great selection of configurations and weight for different end applications. Other great options are the ATI, TCI billet line and ATF Last edited by SSDiv6; 06-18-2023 at 02:23 PM. |
#6 | |
Liked 209 Times in 90 Posts
Two Steps cannot be good for a flexplate either. Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
