Old 06-16-2023, 12:29 PM   #1
Todd Hoven
Guest
Posts: n/a
Default Re: SFI flexplate mandatory in all v8s Jan 2024
My last round in 2019 the flex plate in the Coronet broke completely. Right around where all the bolts were attached. It was a Mopar performance plate that looked like a star. I couldn’t have made another round. Replaced it with a B&M piece. Much nicer and more robust. It definitely broke, probably a few years old and was through a few recerts.
Originally Posted by Paul Precht View Post
There's a lot of difference between a Mopar flex plate and a GM flex plate. The Mopar is much smaller and lighter, one piece and has no ring gear welded on. I don't think its possible for a Mopar stocker to break a flex plate. They do fatigue and crack around the bolt holes but still don't come apart.
Old 06-16-2023, 12:40 PM   #2
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: SFI flexplate mandatory in all v8s Jan 2024
Does any body have a brand name/part number, et al for the 14" replacement unit for my 327? I don't mind replacing it while I'm apart right now, just want to be sure I have the right brand and part number.
Old 06-16-2023, 02:46 PM   #3
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I had that happen on my Cuda back in the mid 70s but it was never a dangerous situation, there's not enough mass, circumference or welded on parts to enable it to come near the danger and damage that a GM flex plate can do.
Old 06-16-2023, 05:09 PM   #4
Hefler
Liked 4 Times in 3 Posts
In the early 2000s in a modified super stock car I had the ring come off of a SFI fleplate just as the car shifted into 2nd gear, it came out from under the car, hit the right wall and then back through my passenger window and into the side of my helmet! It happens really fast to say the least.
Hefler is offline   Reply With Quote
