Old 06-16-2023, 09:34 AM   #1
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Default Re: SFI flexplate mandatory in all v8s Jan 2024
Here we go , didn’t take long for this to happen after unfortunate incident in D-4. I personally would only use an SFI flex plate as I really like my two feet. This rule just insures that the V8 in the other lane has one also.
I assume one came apart? I hadn't heard of the incident in D-4.
Old 06-16-2023, 09:41 AM   #2
4543
Liked 649 Times in 140 Posts
I’m glad that this rule is being adopted! Lots of difference between stock one and a certified one. Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
Old 06-16-2023, 09:59 AM   #3
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
I have been using a SFI flexplate but it has expired. Do they have a 3 year certified life? I can not remember. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 06-16-2023, 10:15 AM   #4
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Like to know how they will be checking that-they don’t check anything these days
Mike Moller
NHRA 203 Q-R-T/SA
Old 06-16-2023, 11:14 AM   #5
greg h williams
Liked 23 Times in 4 Posts
Both Jegs and Summit sell a stock appearing flexplate that is SFI approved.If you have one of these,I suggest that you replace it with a quality piece.I don't know which flexplate was involved in the last D4 race,but we had one of the inexpensive ones a few years back on our B/ED and a section of the ring come off.How can that part pass SFI specs? There are more of these incidents than you would think.We replaced ours with a billet Meziere.Quality part.
greg h williams is offline   Reply With Quote
Old 06-16-2023, 11:22 AM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
There's a lot of difference between a Mopar flex plate and a GM flex plate. The Mopar is much smaller and lighter, one piece and has no ring gear welded on. I don't think its possible for a Mopar stocker to break a flex plate. They do fatigue and crack around the bolt holes but still don't come apart.
Old 06-16-2023, 12:07 PM   #7
Steve Stasko
Liked 292 Times in 147 Posts
I just bought a couple different Chrysler flexplates. I bought an eBay special that had "Meets SFI standards" or something thereabout engraved/punched into it, and then I bought a PRW from Summit. The latter is about an 1/8th inch thicker, and actually has an SFI sticker on it. The PRW unfortunately does not say anywhere on it or in the instructions of where it is made, but I am assuming overseas.
I'll have to take a pic of the other one and post it tonight, but something about it just made me uneasy, so I bought the PRW. I've never had any issues with a Chrysler flexplate of any kind, and don't intend to start.
Old 06-16-2023, 12:29 PM   #8
Todd Hoven
Guest
Posts: n/a
My last round in 2019 the flex plate in the Coronet broke completely. Right around where all the bolts were attached. It was a Mopar performance plate that looked like a star. I couldn’t have made another round. Replaced it with a B&M piece. Much nicer and more robust. It definitely broke, probably a few years old and was through a few recerts.
Old 06-16-2023, 12:40 PM   #9
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: SFI flexplate mandatory in all v8s Jan 2024
Does any body have a brand name/part number, et al for the 14" replacement unit for my 327? I don't mind replacing it while I'm apart right now, just want to be sure I have the right brand and part number.
Old 06-16-2023, 02:46 PM   #10
Paul Precht
I had that happen on my Cuda back in the mid 70s but it was never a dangerous situation, there's not enough mass, circumference or welded on parts to enable it to come near the danger and damage that a GM flex plate can do.
