Liked 166 Times in 46 Posts
what did you do?
Banned
Liked 179 Times in 89 Posts
Use this thickness chart if you do not have access to the old shim or the old gear was not set up correctly.
I also use this chart to start over when I'm having trouble getting a pattern. GM .035 FORD 8"-9" *020 FORD 8.8"-7.5" .030 ALL DANA'S .035 8 3/4 X 1 3/4 PIN .090 8 3/4 X 1 7/8 PIN .020 MOPAR 9 1/4 .020 |
Liked 126 Times in 61 Posts
Instead of honing the bearings polish the ends of the spool and the pinion with wet/dry paper. I won't take much for the bearings to slide on without pressing them on.
Liked 972 Times in 309 Posts
Do you want the bearings you are going to use when finishing slide onto the spool ?
