Old 04-27-2023, 11:23 AM   #1
dragracerray
dragracerray's Avatar
Liked 208 Times in 89 Posts
Default Re: Dana 60 ring and pinion
Joe,
I learned a trick that makes things so much easier. Hone the Carrier bearings so they slip on my hand (ie are not pressed on). Don't get carried away you don't want the bearing sloppy on the Carrier. My engine guy did the honing.
If you are pressing the bearings on you may not be pinching the shims tight. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 04-27-2023, 11:29 AM   #2
littlemanjoe
Liked 75 Times in 28 Posts
Originally Posted by dragracerray View Post
Joe,
That's done. I just realized the attachment didn't go. It's there now.
Mike
littlemanjoe is offline   Reply With Quote
