Old 04-09-2023, 07:03 AM   #1
SSDA Hemi
SSDA Hemi's Avatar
Liked 451 Times in 77 Posts
Default Re: Racepak Sportsman Help
RPM is read off the tach wire to the ignition box. Check the connection, shouldn't be a butt connector but soldered and terminal into ignition box. Do you have a tach connected also or reading rpm through intelligauge or RP dash? Could be a conflict with tach also, but much less likely. I would check wire for damage and faulty connection
SSDA Hemi is offline   Reply With Quote
Old 04-12-2023, 04:32 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Had a similar problem with mine & I called Holley. The 1st thing they said was RF interference. Put new plug wires on and got a filter (MSD8830) that goes on the coil power wire, fixed.
Dave Noll, EF/S ,?/SA 6526
Old 04-12-2023, 08:24 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I had the same problem with my Computech DataMaxx data logger and that's what fixed my problem.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 04-13-2023, 12:51 PM   #4
Dirk Olson
Liked 172 Times in 46 Posts
Sounds like a noise issue. Check how and where the wiring is routed. Stay away from any wires that run fuel pump, water pump, fan, etc. also recheck all your grounds.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
