Liked 10,721 Times in 2,232 Posts
Thanks Mike I will check it out.
Did not get to smell smoke yesterday. Since we will be going to a chasse dyno I had to hookup my trans temp sender, I don't want to fry the trans. Did another Stupid Old Man Trick. I had the shifter in park and the trans in reverse. I found that out when I went to tighten the rear wheels they kept on spinning. The recipe for disaster involves the neutral safety switch located on the shifter. The switch closed allowed the starter to engage with the trans in reverse. It could have been a new garage door and a return trip to the body shop. To adjust the shifter I had to remove the collector, tether, and part of the trans shield. Got it adjusted and put back together. Trans temp sending unit goes in the pipe bung in the pan. I was able to install without too much of a mess. Then it was a one year old birthday party and NCAA Basketball men's quarter finals. Another Good Day! |
Well I did not smell smoke or even got close. Three of the smaller wires that go straight to the positive post had fallen behind the battery and were not connected. I spent most of Sunday afternoon trying to figure out what was wrong. Monday morning I spent rereading the FAST info and checking the simple stuff. Monday afternoon we spent celebrating our 53rd anniversary, my mother-in-law gave us less than a year. Today we start on # 54. Our honey moon car was $400 57 Chevy TwoTen 2 dr post 265 2 barrel three speed manual radio delete purchased from a retired spinster school teacher.
Liked 52 Times in 22 Posts
Happy Anniversary!
After I got all the wires in the correct place the car started like it had been turned off 5 minutes ago. I had some new sensors to try some worked and some did not work. On the cam sensor the ones with a different polarity N/S did not work and the car would not start. Crank sensor only one OEM part number would work.
We did get to smell smoke on our anniversary we were both happy! |
Spent this afternoon figuring out what sensor work and what sensors a dealership hooked me on. Some of the Hemi stuff is getting a little hard to find from non support.
Aaa
I had a question on an installation item and I called the help line and got very good help. The wait was worth it.
