Old 03-17-2023, 08:49 AM   #1
Liked 10,681 Times in 2,222 Posts
Default Re: Dumbo The Flying Elephant
Above the oil filter on the block there are two 3/8 NPT plugged holes. Bottom one goes to the filter and crank driven oil pump and the top one is the passage the the oiling system. I use a three gallon viton seal bug spray to pressurize the system the system. The mess occurres when the hose is disconnected and the plug is installed with my left hand.
Old 03-17-2023, 03:46 PM   #2
Dyno
Dyno's Avatar
Liked 680 Times in 203 Posts
Melling makes a great oil primer. Larry, no matter on fast you are with the pipe plug, it is always a mess, especially the first time before you realize what happens.
Old 03-17-2023, 06:53 PM   #3
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
6th
tommy d is online now   Reply With Quote
Old 03-18-2023, 09:26 AM   #4
Who owns this car, with the peace sign, mag wheels, and four on the floor?
Charlie Daniels
I spent a better part of a day looking for some body parts that I put up to keep dust off of them. I tore the car apart after Indy and just now putting it back together. Sometimes I forget where I put stuff, just another stupid old man trick. I will not get much done this weekend 'cause it March Madness! Its the best of college sports on TV.
I got a lot done today. If everything goes well we should be smelling smoke latter this week. As y'all can see I till have a lot of cleanup to do on getting the wires looking better. It's a real pain to get the valve cover off on the passenger's side just to check valve lash. Headers have to go on in an assigned order. Believe it or not I can get 10 O2's on the car and only have to install one in the pipe before installing the pipe on engine.
I took a picture of the oil filer base with the two plugs that make a mess when I fumble them. Me and the air inlet almost look eye to eye
ID:	66555   Click image for larger version
ID:	66556   Click image for larger version
ID:	66558   Click image for larger version
Old 03-21-2023, 12:45 PM   #5
MR DERBY CITY
Liked 7,904 Times in 1,513 Posts
Smile Re: Dumbo The Flying Elephant
Larry, I expect you to get many things done this week since your Favorite college BB team lost Sunday. Perhaps DUMBO will be out soon .?
Old 03-21-2023, 04:07 PM   #6
Indy Pts race end of April. Maybe in FSS/F, it makes the tires think they’re bigger.
