I've talked to a couple Neon guru's and they seem to think it would only be worth it with a manual and i wouldn't even attempt racing a manual. I wouldn't of thought they would be that bad since you can use the same trans the turbo dodge guys all run but these Neon engines like more RPM. I found info off of a Neon page over a decade ago where someone got a best of 14.96 out of one when the index was 14.95. Hardest part is finding a half decent body. Anything decent everyone wants over 3k for one up here in the northeast. I do know where there's a supposed really clean 96 4dr with a blown head gasket. I keep looking tho not sure if the 95-99 or the 2000-2005 ones are the way to go. The 2000-2005 ones are a couple hundred lbs heavier. Then the question on the 95-99 do you go SOHC or DOHC? Either way the stock cams are really small on all the Neon engines. But so many circle guys race these cars directly against the Ecotec's and have success so maybe it can work? These Neon's stock with an auto are only good for around a mid 17 if you're lucky. Some guys are only getting 18 sec from them.
Billy Kirpens Jr / Pro ET / Street ET 123J @ Lebanon Valley Dragway Stock/Super Stock 123A |
#2 | |
Liked 287 Times in 146 Posts
