Old 02-23-2023, 04:00 PM   #1
Liked 10,746 Times in 2,235 Posts
Default Re: Dumbo The Flying Elephant
The old machinist rule: measure twice cut once; and almost right is still wrong!
Old 03-01-2023, 08:12 AM   #2
Broke a stud off in the intake and had to dig it out. It broke two threads below the surface and damaged those two threads. Straighten the threads with a pocket knife. Got two different ez out kits at Lowe’s that worked very well.
Old 03-01-2023, 08:39 AM   #3
Frank Castros
Liked 2,732 Times in 964 Posts
Larry,
The GEN III HEMI is a bear to work on compared to a RB isn't it.
Old 03-02-2023, 08:06 AM   #4
It’s real tough when I do stupid stuff
Old 03-03-2023, 04:49 AM   #5
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
When will Dumbo first hit the track ?
Jake Biermann
Old 03-03-2023, 12:51 PM   #6
When Patsy can go racing in the motor home. I'm hoping we can get the Holley system installed in the car and on the Dyno before we go.
Old 03-08-2023, 08:03 AM   #7
I’ve been studying the new engine management system from Holley. The first items I’m going to get and test is a backup for every sensor. I would feel very silly to travel 600 to 800 miles to race and have a problem with a $30 sensor.
If two identical air temp sensors vary 3 degrees would I need to change the offset to make the ECU supply the engine with identical A/F and spark of the previous run?
Now that I’ve thought about it a faulty O2 could cause all kind of headaches.
