Old 02-06-2023, 01:30 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Re: Advice on brake lines
Originally Posted by Paul Precht View Post
Brake lines are a pleasure with this.
have one on its way
Old 02-06-2023, 02:19 PM   #2
CMcAllister
Liked 931 Times in 265 Posts
Originally Posted by David Lee View Post
have one on its way
37 degree tooling is available by itself if you're going that route. More cost effective to get the whole kit - 3/16 to 1/2.
CMcAllister is online now   Reply With Quote
Old 02-06-2023, 03:36 PM   #3
Dave Gantz
Liked 251 Times in 125 Posts
I've been using an old Imperial, similar to this one: https://www.ebay.com/itm/18551982762...Cclp%3A2047675
I just learned something this past year.
I was having a hard time stopping a new double flare from leaking. After googling, I found out if you don't quite finish the second flare, when you tighten the flare nut, it will "finish" itself. I.E. the flare will finish forming as you tighten it against the seat. Presto! After making several flares, including making a new line when it got too short, using this technique, it sealed on the first try.
Maybe this is common info, but I thought I'd mention it.
