Old 01-11-2023, 12:52 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: Blanket policies on HP Factors
Originally Posted by TERRY HEMBREE View Post
I questioned Pat C last year why the 68 and 69 350/396 Camaros had different hp ratings because the 68 only had been reduced to 330. He said the reason was because of the intakes and if I wanted him to consider lowering the 69 to 330 then I had to send him both year intakes so he could scan them to see if they were equal. I had no interest in doing that so I left it at that. So now for some reason the Chevelles and the 68 Camaro are at 330 the 69 Camaro is still 340.
Yep, makes no sense at all, and when questioned you'd swear you were talking to a politician.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 01-11-2023, 01:23 PM   #2
1347
1347's Avatar
Liked 1,027 Times in 282 Posts
Have you not taken note the phrase thats been said over and over on here " One of the problems is we have too many combos"?
This starts to fix that problem, but like everything else when it comes to class racers, nothing makes everyone happy. Including myself.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 01-12-2023, 09:06 AM   #3
Chipper Chapman
Well I geuss we should all be running one and only one approved combo, you know, to make it easier on everyone involved.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 01-12-2023, 09:28 AM   #4
pmrphil
Liked 392 Times in 153 Posts
Would that be 10.90, 9.90, or 8.90? Nope, still too many classes.
Phil Molski
PMR Performance
S/C 1623
Old 01-12-2023, 09:48 AM   #5
Billy Nees
Soooooooooooo, how do "they" fix the problem? Go back to the "good-old-days" of not factoring body styles?
Billy Nees 1188 STK, SS
Old 01-12-2023, 10:31 AM   #6
Jim Kaekel
Liked 536 Times in 110 Posts
Personally, I think that much of the issues with the AHFS could be fixed by using a common sense approach. For example, If a 396/325 is rated 325 in a '68 Camaro, I can understand why it's rated slightly less, say 318, in a larger, heavier Chevelle. On the other hand, when there is a 20, 30, or 40 horsepower difference on the same engine in two different bodies styles, that shows no common sense at all.
Jim Kaekel 3836 STK
