Old 01-10-2023, 09:24 PM   #7
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Default Re: SBC header adapter plates
As DanBar said above, check Schoenfeld Headers. You can order a standard header and specify any bolt pattern flange they have (within Reason). It solved a similar problem I had with a set of heads.
https://www.schoenfeldheaders.com/
Larry Merk
Larry Merk is offline   Reply With Quote
