Liked 455 Times in 147 Posts
I believe there's 2 lenghts they make . The single bar comes in two pieces. You can drill several position holes and adjust it to what works on your car. When weld it .
Call Ronnie there, he will answer as your questions. Steve Teeter Stk/SS 620 |
Liked 1,937 Times in 582 Posts
The one on my car is 48 inches long. The adjustment is infinite with the slip tube. I just have a bolt through mine and did not weld the slip tube to allow for more adjustment later. I can tell you that Kens work is absolutely beautiful and top quality. I put studs in the housing to make hanging the wheelie bar easier. Its super nice when changing a ring and pinion the wheelie bar is completely out of your way.
Mike Pearson 2485 SS |
Liked 18 Times in 8 Posts
Once you have the bottom bar pinned or tig welded there is about 3 3/4 inches of adjustment in the bottom bar. The bar has left and right hand rod ends in it so just break the jam nuts loose and you have 1 7/8 inches up or down.
Ken Keir |
Liked 4 Times in 3 Posts
Got it, Thanks What lengths do you build them?
#6 | |
Liked 20 Times in 12 Posts
