Old 12-16-2022, 02:05 PM   #1
340Cuda
Liked 802 Times in 339 Posts
Default Re: Dumbo The Flying Elephant
Who was the vendor?
They deserve a public pat on the back.
Old 12-31-2022, 08:17 PM   #2
Liked 10,738 Times in 2,234 Posts
Had rust on the some of the valve springs. It would seem that might be a place for failure of the spring to start. Single spring without a damper makes me plenty nervous.
Old 01-04-2023, 12:36 PM   #3
I thought we would try an Ovate wire spring. A person would think an engine that is 400 plus inches would have room and valve train support parts, not so. So to get what I think I need we ordered some parts that are too big on the OD and too small on the ID and we think what we need is hidden in the middle. I got some whittling to do.
I hope it’s not another case of buy it, try it, and then put it on the shelf.
Old 01-04-2023, 02:59 PM   #4
Todd Gross
Liked 54 Times in 24 Posts
Hi Larry. I have a 2010 version Drag Pak / 392.
I was really surprised with mine that I couldn't find a dual spring to work with the Heads & T&D Rockers. I used PAC 1427, which is their BBC Stock Eliminator Conical Spring. It's pretty beefy with 500# open and is stable up past 8300 RPM. But it's a single.
I sure would like the security of a dual.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 01-04-2023, 03:16 PM   #5
Yes I would feel more comfortable with a double spring. Has anyone used the Comp Cams double conical?
Old 01-05-2023, 03:30 PM   #6
Matt@PAC
Liked 24 Times in 4 Posts
Larry,
Take a look at the PAC-1238X. It may be too small on the ID, as I cannot remember what the OD of the guide boss is on those heads.
Matt@PAC is offline   Reply With Quote
Old 01-17-2023, 07:50 AM   #7
For now I’ve fit new springs to the head and will change them out after X number of runs. Time to get ready to race.
Old 01-17-2023, 12:57 PM   #8
Going to pick Dumbo up at the body shop today. Looks like we will make
No Problem in February.
Old 01-17-2023, 06:50 PM   #9
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
The 1237X spring can be made to fit.
