Old 11-22-2022, 07:29 PM   #1
SSDA Hemi
SSDA Hemi's Avatar
Liked 451 Times in 77 Posts
Default Re: Good news! R&P Steering legal in SS/AH
Everyone cries "death wobble". How many AH cars have that shake? How much ET do you think that would scrub? Not all the AH cars do this and I believe the scrub is negligible as at the top of low gear thees very little weight on the front tires. In SS/CA my Street Hemi has run almost 150 and no wheel wobble, my steering box is not ground on for header clearance and there is a brace supporting the top of the steering box. This is 155 lbs more than AH. I saw one steering box break with the wobble and there was very little left of it where it broke- ground on heavily for header clearance and no brace up top. Replaced with a cast iron stock style box and believe it is still in car and running over 160.
My big argument against this is this:
1) It is not inline with the Bible (Rulebook) here. A super Stock car uses stock components massaged to a higher level. We start throwing away stock components and pretty soon Super Stock turns into either PRO Stock or Super GAS! Where does it end? We have the R&P, Struts are even safer than these rusty old control arms.... Stock is going down this path right now and it will not end well for either class
2) Once one of the top cars update and gains an advantage so will every other car that wants to play at that level. Even parked cars that are for sale or will be for sale are now worth less. I estimated $5k for updates but I believe that is low in this inflated economy. The big draw at Indy is competitive racing. This will only separate the top cars from 2nd string or slower cars. More expense and less competitive racing = lose/lose
I'm all for safety but not at the expense of the rules. Show me one recent crash in AH caused by a broken, non ground on, non braced box. And if you kick the rods and take out your steering linkage, Call MR2 for a diaper and stock forged steel centerlink .
While we're writing letters, I'm going to petition NHRA for a pro charger to bolt on the front of my Hemi. Much safer on my wallet to make 1050hp.......
SSDA Hemi is offline   Reply With Quote
Old 11-22-2022, 08:03 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
[QUOTE=SSDA Hemi;671262]Everyone cries "death wobble". How many AH cars have that shake? How much ET do you think that would scrub? Not all the AH cars do this and I believe the scrub is negligible as at the top of low gear thees very little weight on the front tires. In SS/CA my Street Hemi has run almost 150 and no wheel wobble, my steering box is not ground on for header clearance and there is a brace supporting the top of the steering box. This is 155 lbs more than AH. I saw one steering box break with the wobble and there was very little left of it where it broke- ground on heavily for header clearance and no brace up top. Replaced with a cast iron stock style box and believe it is still in car and running over 160.
I'm sure you know the B/E body front susp is an entirely different animal than the A body with the A body being junk by comparison in stock form. I have never seen a cast iron manual steering box on any 62 and later A B or E body car, maybe there was one but I must have missed it.
Old 11-22-2022, 11:46 PM   #3
Todd Hoven
Guest
Posts: n/a
Flaming River makes an iron replacement box. That’s what they used in the car that John is talking about
QUOTE I'm sure you know the B/E body front susp is an entirely different animal than the A body with the A body being junk by comparison in stock form. I have never seen a cast iron manual steering box on any 62 and later A B or E body car, maybe there was one but I must have missed it.[/QUOTE]
Old 11-23-2022, 01:59 PM   #4
Spyphish
Liked 679 Times in 180 Posts
While we're writing letters, I'm going to petition NHRA for a pro charger to bolt on the front of my Hemi. Much safer on my wallet to make 1050hp.......[/QUOTE]
Let me write it, I am good at it. Phish
Old 11-23-2022, 07:28 PM   #5
SSDA Hemi
SSDA Hemi's Avatar
Phish, I hope your car doesn't sell. You crack me up and I do believe its personalities like yours that help make the SS/AH class what it is! Love it and LMAO!!
And I have no problem with you writing a letter and asking for your wishes. I am just flabbergasted NHRA makes a rule change as big as that off of 1 letter. Where was the SRAC email or maybe poll the SS/AH racers at Indy. Let majority rule. Let those that are actively participating decide their own fate. I've stated I don't like the rule change because it bastardizes the Super Stock class. Why does NHRA decide the fate of the class on 1 letter especially when it appears to lead the category down the wrong path.
The Hemi racers went down this road some years back with the Hemi head debacle. We learned then that there was no turning back and the class still suffers from the wrath of that rule controversy. This Rack and Pinion deal will be the same way, the big question is where do we draw the line and say enough is enough? Maybe the ratio of racers entering the class changes more favorably to racers leaving
Old 11-23-2022, 09:53 PM   #6
James Hensler
James Hensler's Avatar
Liked 58 Times in 36 Posts
Ok they allowed the R&P but without aftermarket spindles no one is going to change! I have personally talked to several and they all said the same thing NO WAY IM CHANGING
Saying don’t let us run the eliminator is laughable! GT cars have had this **** since jump street
SS/AH
328X
James Hensler is offline   Reply With Quote
Old 11-23-2022, 10:09 PM   #7
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
The rule change was not because of one letter from Phish. We (many SS/AH racers) requested some changes for safety reasons to NHRA 5-6 years ago. I am not aware of any requests to NHRA recently. I believe that there is an underlying rule change to the class coming, Starts with a "D"., but because the drag link goes through the oil pan , it really is not feasible. Moving the steering linkage forward, it would solve this issue. If anyone thinks this change will affect the Superstock class, look around at the GT and Modified classes and what is allowed and explain this to us! QA1 makes a great front subframe for the class to run, mine is on order. (LOL). Dyno. Dan Zrust SS/AH and A/SA.
Old 11-23-2022, 11:20 PM   #8
Spyphish
Dan is right. In 2009 when my car was built a group had signed a letter about steering etc. My Aug. email was answered as " we are already considering it". Thanks for the ego trip, thinking I am somebody. Phish
Considering being head of PGA. New rule, your ball lands on the green, pick ball up, add 1 stroke, move on.
Old 11-24-2022, 07:31 AM   #9
SSDA Hemi
SSDA Hemi's Avatar
James, reread Spy's post above. He IS updating to R$P as will others. Get ready as soon as they show its worth something besides safety..... Keeping up with the Joneses or eat their dust......
Dan as I stated in my first post, my buddy runs a '60 corvette in modified and has to run stock steering and "safety"?!! More like "antiquated"!! Modified I could see allowing a Rack as others. SS/AH is like the Thunderbolts and RO51 cars, built specifically for Super Stock and traditional SS is massaged as was built from factory.
The SS/AH players at the front has changed significantly since 2009. More left than returned and did they leave due to a safety issue over the steering box or linkage? Or ? Many competitive SS/AH cars just parked, some for sale some.... getting antiquated over R&D hp developments or now R$P updates.....
What is the real safety issue here, fear of broken steering box or centerlink through oil pan. I addressed the weak box issue, if its centerlink through oil pan everyone with that application should be fearful and needs this update.
If this rule change was along the lines of SS racing I could stomach it. The days of "everyone gets a trophy" are not acceptable to me. Changing ball on green, Rack and pinion, Hell, lets rewrite the 10 commandments and let me have some fun with the neighbors model wife while we're at it......
Old 11-24-2022, 07:39 AM   #10
SSDA Hemi
SSDA Hemi's Avatar
I will race SS/AH regardless of this rule change. Concentrate on the eliminator and hopefully bucket list drive in Hemi parade. Thanks NHRA!
Happy Thanksgiving to all!
