Liked 348 Times in 152 Posts
That's a tough one. You have to PROVE it was needed at the shop without engine/trans for the repair to be done. Talk to the shop, creativity is your best friend.
Phil Molski PMR Performance S/C 1623 |
Liked 10,837 Times in 2,252 Posts
A tip of the hat to Don Kennedy for his work on getting the problems handled. Thanks Don
Went to the body shop yesterday, one side is done and the other side is being worked on. We should have it easily done before Christmas.
Thanksgiving day and after our meal with the extended family (26 I think) it will be a nice quiet day in the shop without interruptions.
It didn't happen. Last edited by Larry Hill; 11-24-2022 at 10:19 PM. |
Setting coil bind clearance on 392 DP engine.
Check PAC spring height gage for zero. Check height add .103” retainer adapter. Subtract cup and spring shims from gross number to arrive at installed height. Subtract valve lift from installed height to get open spring height. Measure spring height at coil bind subtract open spring height and the result is clearance or interference at maximum lift. Adjust accordingly to get the number you want. The Pac mic is the best I have ever used for accuracy and repeatability. |
We order a couple sets of valves on October 2, 2022 with a promise date of of mid December. I’m happy to say it was promises made and promises kept! Santa Clause has been very good to me.
