Old 11-05-2022, 01:21 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Re: Billet cams and lifter supply
I know Schubecks have garnered a lot of flack over the years and I've seen the damage they can do when they come apart but I've run the same set for 12 seasons and they don't look any different from the day I installed them. I do run more spring pressure than I probably have to trying to make sure they stay in contact with the cam and the cam is starting to show some signs of wear but very little.
I can't believe in this day and age someone can't come out with an "improved" ceramic lifter, especially now that we can run solids and don't need room in the body for the hydraulic plunger.
I doubt any manufacturer out there is going to make roller cams and lifters for my combo so I'll be stuck with a flat tappet setup regardless.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 11-05-2022, 01:44 PM   #2
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
I again ask ,and I add with (no response) how many orders do the two manufactures have at this time ,also it would be interesting to know out of the about 1700 stock eliminator with NHRA numbers even need a ceramic lifter or tool steel lifters that may help answer the questions why Smith went out of business ,and no one has stepped in to make either one
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
