Old 10-30-2022, 12:37 PM   #1
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Default Re: sbc engine block weight
Originally Posted by james schaechter View Post
I have two engines for my cavalier.one is a little m and the other is a bow tie. The dart is over 30 lbs more and I hate that since cavaliers are nose heavy as it is.
At 2680, I can run two full size batteries and some weight in the rear weight box with a 200 lb driver. If I was lighter it would be a non issue. I guess part of all this depends on how much you need to weigh overall and how heavy your car is.
That being said, the car performs well with either block in terms of how it works and as far as hp the engines are virtually he same in hp.
I like to run in G which puts me at a 2680 minimum, but if you run a heavier class and can move weight to the back, I wouldn’t be concerned about a little more weight if you thought the block was too heavy.
I really like the idea of having one lightened, but not enough to spend the $$$
James, what F-R weight percentage do you run and/or shoot for, with your Cavalier?
Andy Friar
Andy Friar is offline   Reply With Quote
Old 10-30-2022, 04:06 PM   #2
james schaechter
Liked 1,443 Times in 302 Posts
Running the car at 2680, I don’t have much choice, it is 52% on the nose.
James Schaechter 3163 STK
Old 10-31-2022, 08:26 AM   #3
Terry Drinkwater
Liked 27 Times in 11 Posts
James, your car looks like it works very well in your photo! Lots of weight transfer.
Terry Drinkwater is offline   Reply With Quote
