Old 04-16-2008, 11:07 PM   #1
pro70z28
Default Billet Aluminum Dash Bezel
Got the gauges picked out I think for the dash project. . I downloaded the ones I want off the net, sized em' to the specs on the site & printed the faces out on the printer. Then I cut some PVC gauge housings on the CNC. They are a little deeper than the actual gauges but that'll insure I have ample room for the real deals down the road. Now I can make a bezel. That outta' keep me busy for awhile.
Cut the bezel out on the CNC. There's a bunch of steps to get this thing cut. I keep thinkin' one BooBoo & it's scrap. :shock:
Got the bezel off the table. Now comes the task of bending it in the right places & at the correct angles to fit the dash.
Got it roughed into the dash cover. Still rough but close enough that I know it will fit. The right wing is 1/2" longer than the left wing, so angles are different. I think I got it purdy' close though. Next is to cut the contour in the fiberglass for the oversized tach & speedo.
{that's a relief}
pro70z28 is offline   Reply With Quote
Old 04-19-2008, 11:05 PM   #2
pro70z28
Default Re: Billet Aluminum Dash Bezel
Got a little further on the dash today. I made plugs out of PVC to form the gauge wells, since these gauges are too big for the original bezel opening.
I did the kitty hair "form the bezel to the dash deal" again. Used vinyl & spray Pam as a release agent.
One last big hurtle for me. TIG welding on the bezel w/o ruining it. I welded some strap aluminum to the top & bottom to stiffen up the bezel & to provide a place for rubber mounting grommets.
Got the bezel just setting in place. It's being held in by the dash bar. Close enough to see what it'll look like.
Old 04-21-2008, 11:39 AM   #3
BIZMANRACING
BIZMANRACING's Avatar
very nice work...
go into business for yourself and sale one to me. i got a 79 camaro it would look great. the cost of gauges would be preety high to. but, hell if you had to ask how much you should not be here.
S/ST 1739
Carlos Mendes
BIZMANRACING is offline   Reply With Quote
Old 04-21-2008, 12:08 PM   #4
pro70z28
If I told you how many hours I had in that thing you would laugh.....
Old 04-21-2008, 05:12 PM   #5
Keith 944
Keith 944's Avatar
Liked 1,876 Times in 577 Posts
man, that does look good, nice to see someone take pride in their work.
Keith 944 is online now   Reply With Quote
Old 04-23-2008, 10:44 PM   #6
pro70z28
Thanks Keith
Old 04-24-2008, 08:08 AM   #7
CPOlesen
That is a super job. I wish I had that talent. If I can't make it with Duct tape and J B Weld then I'mn toast.
CPOlesen is offline   Reply With Quote
Old 04-25-2008, 10:14 PM   #8
pro70z28
Thanks CPOlesen
Old 05-04-2008, 11:17 PM   #9
pro70z28
Got the bearing housing for the steering column (firewall) done this weekend. Now all I need are those back ordered steering column parts.
I got one last thing done this weekend. I pulled the old dash out & used the glove box as a plug to make this mold. Got a couple little places to touch up and then I can make up a couple fiberglass glove boxes to finish off around the intercooler. The door has that imitation leather pattern, & the Camaro logo. They came out O.K. so far.
Old 05-05-2008, 09:56 PM   #10
pro70z28
Little steering column mock-up tonight. The Mark Williams quick release hub came today.
