Liked 279 Times in 68 Posts
Carb and heads are really big for a fairly mild motor. Changing the cam and moving the power band up with a looser converter might work but it would be a lot of testing. I’m guessing a 6400 rpm converter would help you right now. A good 200 cc head would help a bunch.
Greg Hill 4171 STK |
#2 | |
Liked 3 Times in 2 Posts
#3 | |
Liked 977 Times in 312 Posts
1989 Camaro Iroc-Z I/SA B&B Auto Machine Shop. Last edited by Glenn Briglio; 09-28-2022 at 09:27 PM. |
Sounds like your convertor is pretty loose, slippage wise. My 85 Mustang was 3100 pounds with driver, also had 4.88 gears, although I ran 9 x29 and 9x29 1/2" slicks, and at 130 MPH, I was only revving 7000-7100 across the finish line. My car was a stickshift (Jerico 4 speed), so no convertor slippage, but 8000 RPM at 130 with a 28" tall tire seems awfully high. I previously ran the car in Stock, so it had factory type suspension, with Maximum Motorsport non adjustable LCAs, and adjustable uppers, with Strange single adjustable shocks, and typically ran mid 1.3 60 foots, with a best of 10.15 at 130 MPH with a flat tappet, pump gas 331 cube SB Ford engine. Seems that you have a pretty large carb, my engine was 24 cubes smaller, and a Holley 650 was plenty.
#5 | |
That was a great running car! What was the whole engine combination? Last edited by casrak7; 09-29-2022 at 12:26 AM. |
It was a stock 5.0 block, with a 3.25" stroke Eagle crank and rods, with flatop pistons. Cam was a solid flat tappet Comp Cams (.560ish lift, 252@.050 duration), out of the box AFR 185 heads, Victor Jr. intake & 650 DP Holley. Set of cheap 1 5/8" FlowTech long tube headers, Used a Jerico DR4, and 4.88 gears in the 8.8, with 9x29" Hoosier slicks. Dumped the clutch at 62-6400 RPM, shifted at 6800, 7000 at the finish line. Now running a "big bore" 347 SBF, (4.125"x3.25", Dart block), flat top pistons, smallish hyd. roller cam, AFR 185 heads, Parker Funnel Web intake with a Holley 750. Same headers, clutch, but switched the Jerico for a G Force G101A 4 speed, gone a best of 10.01 at 133 mph in my 78 Fairmont (2900 pounds), bracket car, still mid 1.3 60 foots.
Got in some better air, 260ft da. Went 10.32@131.31, with 6.59 eighth@105.4. 1.43 60 ft. Still need the converter loosened some. Going to run some valve lash loops, and try some thinner oil for the heck of it next time out. Not enough time in the year to send the converter off right now. Maybe get a mid 20.
The manifold has some work done, and I was trying to keep a little airspeed in the engine. The strip dominator is a pretty good manifold compared to most actually.
