Old 09-24-2022, 01:35 PM   #1
herbjr
Liked 83 Times in 32 Posts
Default After a heads up run
Why would a stocker need to drain the fuel after a heads up run. #asking for a friend.
I know the answer and it passes fuel check.
herbjr is offline   Reply With Quote
Old 09-24-2022, 01:40 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,181 Times in 972 Posts
Default Re: After a heads up run
Dry ice
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-24-2022, 01:42 PM   #3
James Perrone
Liked 1,824 Times in 426 Posts
Some people run different fuel in a heads up
Dry ice just makes it cold.
james perrone 1290 STK
Old 09-24-2022, 04:20 PM   #4
herbjr
There is an additive that passes I'm sure the ones who know wont say a word,
Old 09-25-2022, 07:09 AM   #5
james schaechter
Liked 1,430 Times in 298 Posts
Why the discovery channel drama?
If you know, and you care enough to post this, spit it out man! LOL
James Schaechter 3163 STK
Old 09-25-2022, 10:05 AM   #6
James Perrone
What the secret sauce
I’m a cheater and I don’t know
Old 09-25-2022, 11:17 AM   #7
bubski
Liked 165 Times in 60 Posts
Interesting question your friend has there Mr Herb jr !!! Bubski also thought it was intriguing and phoned a friend !! Apparently there are fuel additives that the masking agents used to dupe the fuel check will break down rather quickly and may be an issue later on in the day !! Bubski just wondering why they don't put the "fuel check fuel" in the fake radiator overflow like they do in D7 and pull up about a 100 feet away from the scales so a few semis can get weighed and get your fresh sample for tech !! Its good to see someone paying attention !! Cheers !!!
bubski is offline   Reply With Quote
Old 09-25-2022, 11:58 AM   #8
GTS340
Liked 1,344 Times in 410 Posts
See it is possible to learn something new every day even at 65 yrs old. I'll try not to be first every time down the track to verify here in D7 we cheat on fuel.
As far as changing fuel. I'm too lazy and run C-11 all the time but some run the less expensive till the time to get a little extra is needed. Possibly in the third person mode your invisible too.
Paul Haszlauer
Old 09-25-2022, 02:31 PM   #9
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Do you just dream this crap up? Such a pathetic attention grab at every chance.
Us racers police ourselves pretty hard. You can bet you Bubski ash any racer involved in a heads up would call out a competitor that stopped to dump fuel or switch lines. Second tech officials for the uneducated do peak under the hood when giving the sample. Not always but more often than you might think. Plus there has not been a competitor caught doing something like this in decades if ever.
Old 09-26-2022, 08:03 AM   #10
Tom Meyer
Liked 354 Times in 120 Posts
More than likely it was C25, also the secret sauce that makes there cars go faster is a mix of time, effort, and money. Congratulations to both racers for having bad *** cars and were not afraid to turn them loose. Truly this is what class racing is all about. Tom
Tom Meyer 5240 SS Stock ???
