Old 09-05-2022, 10:56 AM   #11
rod butcher
Liked 132 Times in 27 Posts
Default Re: Titanium valve check...
They also checked Joe Santangelo during tear down for titanium valves doing the mass volume test and weighing valves.
rod butcher is offline   Reply With Quote
Old 09-05-2022, 01:59 PM   #12
Rick J
Liked 73 Times in 37 Posts
Originally Posted by dwydendorf View Post
The tech guys could sonic check for hollow stems, they allready have a sonic checker for cage thickness.
Hollow stem steel valves are legal.
Rick J is offline   Reply With Quote
Old 09-05-2022, 02:52 PM   #13
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
I know they are legal, just mentioned that they could use the sonic checker to determine the mass lost by drilling the stems out.
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
Old 09-07-2022, 03:06 PM   #14
GTS340
Liked 1,341 Times in 408 Posts
Just need a test for acid has been poured into the head now.
Paul Haszlauer
7019 C/SA
GTS340 is online now   Reply With Quote
Old 09-07-2022, 07:45 PM   #15
Frank Castros
Liked 2,717 Times in 957 Posts
Originally Posted by Bill Ringer View Post
There are devices that can conclusively ID the material without removing the head, just remove the valve spring. With the spring off one can check the stem with an XRF metal analyzer. These are accurate and as small as a few pounds. The cost can be an issue as ones just for this type of test would be around $15K new, less for refurbished plus, they can be rented. If there are other components such as chassis parts that need the material verified it's possible the cost could be justified. I've used these, they're super easy to use and accurate.
This article has all the basic info on this technology - https://blog.metalvp.com/articles/ha...-honest-review
Bill Ringer needs to get back to the track with his High Country 'Cuda.
Old 09-08-2022, 04:01 PM   #16
jimi vignogna
Liked 17 Times in 3 Posts
I was at the tear down on Saturday morning to speak with Travis and he was weighing Chucks valves , It was nice to see nhra actually checking stuff , I wish they had more man power to do tear down like it used to be.
jimi vignogna is offline   Reply With Quote
Old 09-08-2022, 04:44 PM   #17
Rick J
Oh ok, it's just a calculation to determine weight loss.
