Old 08-21-2022, 09:44 AM   #1
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
Transmission pan took some damage from the crash and needed replacement. Went with the full length version this time.
Todd Geisler is offline   Reply With Quote
Old 08-21-2022, 09:50 AM   #2
Todd Geisler
Got the transmission Rife sensor block plumbed for line pressure, converter charge pressure and trans fluid temp.
Old 08-21-2022, 09:56 AM   #3
Todd Geisler
Floors slid into place.
Old 08-21-2022, 09:58 AM   #4
Todd Geisler
IAT sensor bracket.
Spacer drilled for a remote mounted IAC valve.
[img]https://i.imgur.com/95iawgK.jpg[/img
Little bracket to hide the IAC valve under the cowl panel.
Old 08-21-2022, 10:01 AM   #5
Todd Geisler
Put the car on the ground to set the initial right height, then work on the front end alignment.
Old 08-21-2022, 10:03 AM   #6
Todd Geisler
Spent a little time doing the final fitment for the Racecraft Inc strutless wing. Need to drop that off at the body shop this week for paint.
Old 08-21-2022, 10:08 AM   #7
Todd Geisler
This week the plumbing was completed. I used Brown & Miller PTFE lined, aramid fiber braid hose with their crimp on hose ends. Light weight, very flexible and should last for a very long time compared to rubber lined hose.
