Old 08-11-2022, 04:28 PM   #1
Liked 11,011 Times in 2,263 Posts
Default Re: Dumbo The Flying Elephant
Getting ready to check where the cam centerline is.
Old 08-11-2022, 07:11 PM   #2
Cam is where it’s supposed to be. I should be able to fill some more holes and stretch some bolts tomorrow.
Building this on a bench has been a little different. The more I work on it the harder it is to wrestle into the next position.
Has anyone looked up ring gap placement for the five different parts of the ring package. Several ideas to look at.
Old 08-12-2022, 11:19 AM   #3
340Cuda
Liked 805 Times in 341 Posts
Larry,
Page 2 of the Total Seal installation sheet has their recommendation for gap placement:
https://assets.website-files.com/5ec...heet2010_2.pdf
Bill
Old 08-12-2022, 09:33 PM   #4
There are other sites that have a very different placement. I thought it was interesting.
Old 08-13-2022, 05:57 AM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
And then there is the issue of the rings turning on pistons after running.
Old 08-13-2022, 07:43 AM   #6
So that’s how the ring gaps sometimes get lined up over each other. It’s such a physics problem.
Old 08-14-2022, 08:41 AM   #7
Getting closer to smelling smoke. Front cover, water pump, damper installed and torqued. Holding the block with one hand a pulling the damper bolt to
129 Ft/lbs it took a few try's but I got it done. Checked TDC to the ATI damper it was spot on. Today is head day. The heads are easy. Its the pushrods and valve train that is more fun than an empty barrel.
