Old 08-03-2022, 07:44 AM   #5
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Default Re: Mopar T/A reverse shift 3 speed clean nuetral setup
Originally Posted by SDS Inc View Post
So if your are saying that you adjusted the shifter in 2nd gear position and then when you pull into the clean neutral spot it drags the high gear clutch some....so does the one i have. Just cheat the adjusting screw towards the clean n 1 or 2 turns. Been running it like that since installed. There's enough slop in it that it wont hurt anything.
It got corrected, and Johns method worked great! Thanks!
Eric Merryfield 1883 STK
