Old 07-18-2022, 02:04 PM   #11
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: PJ1 shortage
Not that I want to give THAT show any attention, but they had a chemist create this; http://pimpjuicetraction.com
Dave Noll, EF/S ,?/SA 6526
Old 07-18-2022, 03:55 PM   #12
Barry Polley
Guest
Posts: n/a
It might not be good for the wheel speed cars on a prepped surface??
Too much hook and tires start chunking. Hope they have it figured out or we will all be doing "No Prep"
Old 07-18-2022, 05:11 PM   #13
Billy Nees
OK! I'm good with that!
Billy Nees 1188 STK, SS
Old 07-19-2022, 02:56 PM   #14
nhramnl
Liked 358 Times in 83 Posts
I have had good success with Elmer's. You just apply a thin film to the track and the tires, and allow it to become tacky before you pull up to stage. I've also read that it's very good for the environment (creates no carbon dioxide). Works on electric cars, too.
Old 07-19-2022, 05:58 PM   #15
Jeff Stout
Liked 708 Times in 285 Posts
Dr Pepper syrup has worked the best
Old 07-20-2022, 09:47 PM   #16
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Same here! Pretty sure my Super Street car would be ok too!
Lane Weber
Old 07-21-2022, 10:01 AM   #17
BKSG1198
BKSG1198's Avatar
Liked 1,307 Times in 399 Posts
It's basically all glue that is becoming an issue, PJH & VP. VP has come out with a new formula of glue that needs more attention than most stuff. It basically bypasses the chemical that they would get from Germany. In the past for cars like ours (Stk/SS, .90) it was spray the full 1320 in the morning and drag or rotate the rest of the days to keep the glue where it needs to be, with adding gold dust and a small mist to the starting line to cover bald spots. The new VP needs to be drug, rotated and cars going down as a normal pace for it to work properly. They have been using the new VP at Cecil this past weekend and mixing it with PJH to come up with a formula that could work but, still trying to find the right mix. They were spraying and dragging on a regular basis after almost every qualifying group of .90. The chemical that is missing that that "stick" they keep the cars glued to the track and pulls your shoes off when you're walking. I have heard that Atco & Leb Valley have plenty of glue but, some other tracks have already called me about going to 1/8 mile until they can get some in.
Old 07-21-2022, 01:50 PM   #18
Adub464Q
Adub464Q's Avatar
Liked 478 Times in 91 Posts
There is nothing wrong with the VP stuff, it just takes a different approach as you detail. What we have realized with our local tracks (Ardmore/XRP) is that it take a lot of dragging on the VP compound to make it work correctly. You cannot just spray some glue down, that makes it even worse and will make it slick as ever.
With all this traction compound talk lately, I think we are forgetting the responsibility of the organizations and the tracks. Their responsibility of the track surface is to make it SAFE, not to make it the best starting line of all time. It is the drivers/cars responsibility to make the car work with the track.
The above often gets lost when people start complaining about track prep.
Austin Williams
3 SG
464Q STK SC
Adub464Q is offline   Reply With Quote
Old 07-21-2022, 04:51 PM   #19
Keith 944
Keith 944's Avatar
What we are seeing here is more down track. starting line can be dealt with and at this point is still working manageability
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-22-2022, 06:48 AM   #20
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
Austin I accidentally came off the throttle stop in low gear the first pass when I was at XRP. It didn't spin although next thing I know it was banging the chip. I recently found out D4 had been using VP at the Division races most of the year.
Regan Wilson is offline   Reply With Quote
