Liked 237 Times in 126 Posts
A bit late but a bubble flare is a European standard and not common on US cars. Not sure its road legal in this country. Inverted double flare is stronger. Always match flares and fittings. Here's a chart.
https://www.mpbrakes.com/images/MPB-F200-22.pdf
Liked 1,583 Times in 582 Posts
A word of caution.
If you are using a bubble flare, make sure the mating components are designed for a bubble flare. The flare has a different shape and will not fit into double flare connections. You cannot connect a bubble flare to a double flare seat. They have a built in crush surface which means that the flare can not be reused. You also can not connect a bubble flare to a double flare seat. |
Liked 6 Times in 5 Posts
They've been around for a while on European cars at least. I'm working on an '81 Porsche 911, its brake system has all bubble flares.
Liked 125 Times in 59 Posts
Something I would like to warn everyone about both styles. Once you get the perfect flare on either you probably forgot to put the nut on the line. LOL
Liked 354 Times in 135 Posts
#6 | |
Liked 133 Times in 76 Posts
