Old 07-05-2022, 10:40 PM   #1
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
For the coil harness I decided to install a Mil Spec connector on each side to pass the wires through the firewall. This allowed me to run all the coil wires through the firewall and do the needed splices inside where I had more room to stagger them and where they would be more hidden behind the dash.
Todd Geisler is offline   Reply With Quote
Old 07-05-2022, 10:45 PM   #2
Todd Geisler
One other small wiring project completed was the engine grounds. I needed to connect several large gauge cables to the back of the passenger cylinder head, but there was only 1" of clearance and near impossible to get s bolt started, so after some searching I found a stud that worked.
Old 07-05-2022, 10:47 PM   #3
Todd Geisler
One final detail recently was to sand the powder coating off the chassis tag and polish it up.
Old 07-06-2022, 03:44 PM   #4
jims5600
Liked 21 Times in 9 Posts
Todd,as you usually do,the workmanship is superb. It is a pleasure
watching your build. Thanks for taking the time to keep us posted on
your progress.
Jimmy
jims5600 is offline   Reply With Quote
Old 07-06-2022, 04:12 PM   #5
Todd Geisler
your progress.
Jimmy
Thanks Jimmy.
I just hope people enjoy following along and can get an understanding of what it takes for a build like this start to finish.
