Old 04-16-2008, 08:11 AM   #1
The Colonel
Default 65 Biscayne
I just acquired a 65 Biscayne with a 12 bolt/4 spd., and a complete 1965 396/375 hp motor not original for the car. Car is originally 230 6 cyl. 3 speed floor shift.
My question is....what class/classes would it fit into with the 396? Is it feaseable? or should I go the 283/327 route? I have a 1966 283-2 barrel motor also.
I'm a bracket racer, and am about thinking about trying something different. Any help or suggestions would be appreciated.
The Colonel is offline   Reply With Quote
Old 04-16-2008, 09:21 AM   #2
Liked 1,814 Times in 413 Posts
Default Re: 65 Biscayne
Go to the NHRA website, under the "rules" tab at the top of the page, you'll get a drop down menu that shows the "Stock Car Classification Guide". The guide will give you the basic information about the car and the engines/transmissions available, the curb weights, the HP factors, and what the class factor is. The classes start with AA, which is 7.5 pounds per HP, and each lower class is 0.5 pounds more per HP, so A is 8.0, B is 8.5, and so on. At 9.11 pounds per HP, the Stock Car Classification Guide shows the 1965 Biscayne 396/425 (the 1965 396 is factory rated at 425, not 375, but NHRA rates it at 385HP with iron heads) to be a natural C/S car. It cannot run the 396 with an automatic transmission, by the way. It could possibly run B/S or D/S with the 396 as well. It's a fairly heavy car, I'm not sure how quick it would be, or how hard on parts. But the thing would be way cool.
Old 04-16-2008, 10:22 AM   #3
The Colonel
Thanks Alan, I have alot of researching ahead of me. The car is in a million pieces, but new quarters, floors are already done. When I first saw it, I thought this would make a pretty cool stocker with the B/B 396 and 4 speed, but hard on parts will probably be an understatement. I also have 65-66 396 325 h.p heads that have been in my basement for years that are from my first car back in 1985; 66 SS 396/325 Impala H/T. The car was such a basket case, the motor was all that was worth keeping at the time.
Knowing what you know...what would you do with it?
Thanks Again...Bob Sanders
Old 04-16-2008, 10:30 AM   #4
Don Himes
Another Joisey boy ran that combo with a great deal of success many, many years ago. Does anybody know if Bill Izikowski(Spelling?) is still around?
Don Himes 2075
Don Himes is offline   Reply With Quote
Old 04-16-2008, 11:59 AM   #5
John Mason
Thumbs up Re: 65 Biscayne
Don,
Bill's car was a 66 427/425 out of Duffy's in Red Bank. Very successfull. Runner up to Bortman for World Champ. Last I heard he was a service manager for a Chevy dealer somewhere in "Joisey".
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 04-16-2008, 12:52 PM   #6
Rory McNeil
Liked 1,103 Times in 301 Posts
Back in the mid 70`s, a friend ran a 65 Biscayne in SS/KA with some sucess, using a 325HP 396 Turbo 400. Later he put the running gear in a 65 Impala wagon for SS/OA, which ran really well. I don`t know how well this combo would work in Stock however. I believe that the 65 396 "Big Car" was the first to use the Turbo 400 trans.
NHRA 6390 STK
M/S 85 Mustang
Old 04-16-2008, 01:37 PM   #7
Jack McCarthy
Liked 474 Times in 117 Posts
Red face Re: 65 Biscayne
i ran a 65 impala wagon 396-325 in k/s and k/sa YEARS ago...before aftermarket parts were ok... went through a ton of T-10's and eventually broke lower control arm mounts off of frame (had to be factory then)
but it was fun !!
fits o & p /.sa with 283... cheap date, and i have a few parts
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 04-16-2008, 02:25 PM   #8
The Colonel
Changed my mind already.
Old 04-16-2008, 05:52 PM   #9
The Colonel
The 325 horse puts me at a natural I/SA it appears. I have a couple questions that are not clear.
NHRA has a Holley carb# issued, and also transmission choice is not clear. My 66 396/325 had a th400 and Quadrajet. Is the Holley a replacent for the 4GC Rochester? and they did not put a Powerglide behind the 396 big cars did they?
Old 04-16-2008, 09:52 PM   #10
Knowing what I know (and maybe that ain't much) I'd probably see if I couldn't get it light enough to go B/S.
