Old 05-28-2022, 10:17 AM   #1
Jim Whitehead
Liked 150 Times in 41 Posts
Default Metric 200 Help
Looking for part # for front yoke on a metric 200 THANKS Jim Whitehead
Jim Whitehead is offline   Reply With Quote
Old 05-28-2022, 12:37 PM   #2
Charles Stewart
Liked 754 Times in 213 Posts
Default Re: Metric 200 Help
This may help you?
https://www.summitracing.com/parts/sum-731000
Charles Stewart is offline   Reply With Quote
Old 05-28-2022, 05:22 PM   #3
Originally Posted by Charles Stewart View Post
Whitey, Need to know the U joint size in your application. Std. Chevy, external clips, T400
internal clips,...or 1350 , as above, 1 ton truck joint.
Old 05-28-2022, 11:00 PM   #4
Jim Whitehead
1350 u-joint. Thanks for the help.
Old 05-29-2022, 01:33 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Same yoke as a Power Glide or a THM 350.
Old 05-31-2022, 06:13 AM   #6
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Metric 200 Help
Good morning to all,
The output shaft diameter and spline count is the same from a TH200 transmission as is a Power Glide and a TH350. As Mark pointed out you will need to know if you have a standard U-Joint (1310) or the larger U-Joint (1350) . I switched my stuff to the 1350 U-Joints, although I never had any problems with the smaller 1310 U-Joints. I switched when they started putting in roller tail shaft bearings in the Power Glides and they didn't make hardened yokes for the 1310 U-Joint style. I hope this helps, have a good day!
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
