Old 05-27-2022, 10:14 AM   #1
68Coupe
Default Re: Question about adding weight.
So in the trunk over the rear end would be better than as far back and as high in trunk
68Coupe is offline   Reply With Quote
Old 05-27-2022, 10:39 AM   #2
Jeff Stout
Liked 704 Times in 281 Posts
Check out Kevin Wilson on YouTube. 1 of his videos talks about where and what weight placement does to a car. Very informative. Also he talks about shocks, 4 link, ladder bar set up for all kinds of racing.
Old 05-27-2022, 11:04 AM   #3
SSDiv6
There are lots of parameters to be considered such as the weight of the vehicle, wheelbase, class, type of suspension, horsepower, and other factors.
After spending time scaling different cars for Stock, Super Stock, Comp Eliminator, Top Sportsman, and other classes putting the weight forward of the rear end is the best compromise and maintaining 52% to 54% of the weight in the nose.
Old 05-30-2022, 07:59 PM   #4
Liked 10,758 Times in 2,236 Posts
How many of them had a four link.
Old 05-31-2022, 09:46 AM   #5
SSDiv6
All the Comp cars, and some of the Super Stockers had 4-Link.
The Stockers, and some of the Super Stockers had Calvert suspension.
Have never touched a ladder bar car.
Old 06-01-2022, 10:03 AM   #6
Charles Stewart
Liked 754 Times in 213 Posts
You can add a certain Stock class section on your list: Factory Stock.
Upper control arms are adjustable (heim joints). Upper control arms brackets at the frame have 2 positions to add tuning. Lower control arms have bushed ends and only one hole on both brackets (frame and housing). But, I don’t see any rules regarding the holes position on those, neither rules regarding certain dimensions for those brackets. Also, I don’t see any rules regarding the length of those control arms.
Charles Stewart is offline   Reply With Quote
Old 06-08-2022, 08:47 PM   #7
Bob Shaw
Liked 317 Times in 62 Posts
For the best weight transfer hang it on a pole 10 feet in the air and 10 feet behind the car.
Since that is not very practical you should place the weight as high and as far to the rear as you can according to the rules.
Bob Shaw V/SA 515
Bob Shaw is online now   Reply With Quote
