Old 05-23-2022, 08:07 AM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Question Fast XFI 2.0 minimum battery specs
For the new FGT project Dart sport, for max weight reduction for a head ups run etc.
No alternator of course, two battery slots in trunk
any one ever run a single braile AGM 17 pounder?
It will still get down to the weight class desired with a single tried and true optima redtop AGM. But in a head ups run, you need everything you can get.
I know they are used frequently in stockers, with altenators of course.......
Maybe a Indy qualifier has done this?
Thanks
Eric
Eric Merryfield 1883 STK
Old 05-23-2022, 12:54 PM   #2
4543
Liked 646 Times in 140 Posts
Default Re: Fast XFI 2.0 minimum battery specs
Eric, I called FAST a while back with the same question. There response was if I remember correctly was 10-10.5v. It was way lower than I expected. I tried to locate amperage draws for the fuel pump, ignition, and water pump. Thought that might be useful too. Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
