Old 05-05-2022, 06:57 AM   #1
Liked 10,852 Times in 2,254 Posts
Default Re: 2 step low rpm
If your car wants to push through the lights look at your rear brakes. On a hot track the front tires will side very easy.
Old 05-05-2022, 12:13 PM   #2
340Cuda
Liked 805 Times in 341 Posts
I used to have problems pushing through the lights. I have dual rear calibers now and not a problem.
Old 05-06-2022, 11:54 AM   #3
Robert Simpson
Liked 20 Times in 12 Posts
I have a adjustable MSD chip in a footbrake car a OHM meter is nec to check it but you can make a quick change in the car and see. Slightly diff question would anyone speak to me about what changes are needed to be done to a Qjet to use a 2 step on my footbrake car. Thank You
Robert Simpson is offline   Reply With Quote
Old 05-06-2022, 12:47 PM   #4
Danny Ashley
Liked 110 Times in 29 Posts
Robert: In some cases, it may be necessary to tighten the air valve tension slightly when going from foot braking to 2-stepping. It depends on the tension you have as a starting point. It could be that it's tight enough and you won't have to do anything. I would try it as is and if you notice any "fluttering", then tighten it a little. Hope this helps.
Danny Ashley is offline   Reply With Quote
Old 05-08-2022, 10:06 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Just buy an 8735 MSD Launch Control….
It takes 2 chips 1 for burn out and 1 for high RPM, but the Launch Control has dials to set the leave RPM
Easy, Peasy
Bob Mulry 7516 STK
A & M Motorsports
