Old 03-29-2022, 04:57 PM   #1
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Default Fuel Pressure on a Bypass System
What is recommended fuel pressure on a Holley Carb (4160) dual inlet, with a bypass style system? Aeromotive pump and bypass regulator 1/2 inch lines for primary and return. 6-6400 rpm range.
trying to see if there is a baseline.
Overkill is Under-rated
stocker396 is offline   Reply With Quote
