Liked 8 Times in 2 Posts
Hope this is the right sub forum to ask this…
I want to get started in drag racing, with the aim to run stock. I got the NHRA rule book on its way and have taken the time to read through the book online already. I have built motors for rebuilds (nothing fancy just warmed up a bit from stock). I have been spending some time here reading through some interesting threads. I currently have a stock 1998 Jeep Grand Cherokee 5.9 limited and a 1992 ford ranger standard cab 4 cylinder manual trans. The Jeep I rebuilt the transmission recently and did a transgo shift correction kit. Other than that, both cars are completely stock. The advice I need is, which of my two vehicles would you choose to start racing with and why? I can see that with the Jeep (nhra puts this in the m/s class) it has an advantage of having a 360, trailing arms that act like four bar suspension, coil springs on the rear and it’s a limited slip rear axle. Disadvantage is it’s all wheel drive. That is a lot of friction to overcome to put the power to the ground. With the ranger, running a slow class would be cheaper and allow more room to learn to drive the track. I know that first thing would be having to swap the rear end as the current axle won’t hold up to anything more that the severely tired 2.3 Lima that’s in it right now. Thanks in advance. I should add that I have grown up with family members that are hot rodders, so have been around and researched building up decent v8’s. I just haven’t built a nice motor for myself yet. Last edited by 5.9magnumjeep; 02-24-2022 at 01:08 PM. |
#2 | |
Liked 869 Times in 165 Posts
1189 F/SA Defunzalo Racing Enterprises |
Liked 886 Times in 238 Posts
It may not be listed in the guide ,but the ZJ Grands were available as 2 wheel drive models with a straight tube front axle ,as were all Jeep models . there was a fairly strong market for the rear wheel only models in southern states where the 4 wd was not really necessary and the Jeep were seen as status "driveway ornaments ". The Jeep dealership I worked for always kept at least one of each in stock
There may be potential in the combo ,but it surely will not be an inexpensive build to get it competitive . Do a LOT of research before diving in . It may be wiser, and possibly cheaper to start with a known combo. Look into Billy Nees' posts on "DIME ROCKETS" for some ideas.
Liked 924 Times in 262 Posts
As always, buying a car, or truck, that is done and raceable, even if it's not way under, is a good idea. It will allow you to get to the track and learn how to race, which is not the same as learning how to put a car together.
Will likely save you a lot of time and money spent unwisely. |
Guest
Posts: n/a
WaIt till 2023 to decide your class. What’s good now m i g h t not be so good then.
#6 | |
Makes me wonder about finding a front tube axle setup, pull the transfer case and put on the tail shaft housing from a dodge truck with the 46re. |
Guest
Posts: n/a
#9 | |
My advice? Do a project that you know you can get done AND afford to get done. Don't start a project just because you have the car. If you want to go fast, don't build a lower class car. If you want to build cheap, don't build a higher class car. The Jeep is an interesting combo (and a good one) but it won't be cheap OR easy. The Ranger could be a good combo but it could get expensive in a hurry if you're not a good DIYer. There are a good many "starter" combos out there that you should be able to get and finish without getting disgusted and/or broke.
Liked 493 Times in 231 Posts
Never seen a Jeep in Stock before
Jake Biermann |
