#1 | |
And I believe it’s 6.90 1/8 mile. 7.00 was old ihra index
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 02-17-2022 at 08:07 AM. |
Liked 885 Times in 238 Posts
Just my opinion ,but at over 4000 pounds a 5 point roll bar is not going to offer much protection in the event of a crash at 120 or for that matter any speed . A lot can happen on a 1/8 mile run , or after the finishline , especially on small tires .
You should definitely consider a cage . If street driving is a consideration, a 8.50 or slower cage can be built with removable side bars .
OK being I can’t post a picture I will write these out these are the numbers for a flat out pass in my 3800 pound three speed small block Chrysler 3.90 gears 8” ATI converter leaving @3000 footbreak on Hoosier 10x 28 dots @ 2800da
1.537 4.452 6.948 98.12mph 9.121 10.969 121.50mph
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 02-17-2022 at 01:25 PM. |
Liked 431 Times in 224 Posts
On my door car, multiplying the 1/8 mile ET x 1.584 gets you the 1/4 mile time.
The factor is a little different for my dragster, but still very close. I would imagine that a supercharged combo will run the back half harder, and also MPH well for the ET. The one complete run that you posted, the factor was 1.558. Applying that to your 7.32 nets a 11.404 in the 1/4. In any case, I agree with Keith that you will likely be quite a ways from 135 in the 10.90 ET range.
S/ST 51 S/C 53 |
Liked 7 Times in 6 Posts
Glad i'm not too crazy. I was pretty sure 125ish would be about right but kept doubting myself.
I know going from 8psi to 12psi of boost will pick up alot, especially down low, assuming the converter doesn't eat it all up. But i'm still working alot of things out and have a long way to go on suspension - I still have a stock leaf pack and shackles. I just ordered a set of Corbeau seats today to complement the rollbar going in. To Tom's credit, it's a heavy truck with C-clip axles and drum brakes indeed, but it's also all factory steel, so I'm trusting in the factory cab strength if something goes wrong. Using my tax return on the seats and roll bar. Next winter's project will be a Ford 9" swap, aiming for the Dallas divisional of 2023 to get into S/St. |
[QUOTE=DailyDriverSst;657547
But i'm still working alot of things out and have a long way to go on suspension - I still have a stock leaf pack and shackles. Using my tax return on the seats and roll bar. Next winter's project will be a Ford 9" swap, aiming for the Dallas divisional of 2023 to get into S/St.[/QUOTE] Street/strip go with the caltracs mono leaf, shocks, and bars. They work great!
#7 | |
Calvert didn't make/brand shocks yet when I put it all together, or I would probably have those too.
S/ST 51 S/C 53 |
