Old 02-13-2022, 03:33 PM   #1
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Default Re: Shipping weights
Just drop the 170 rule.
Bob Bender 144 O/SA
Old 02-13-2022, 04:23 PM   #2
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
Just two questions to go with this "eliminate the shipping weights thing;
Will the Tech guys be checking for ballast? And will they be tossing cars out that are carrying over 500 lbs.? It's a "General Regulation".
How long will it be before the Racers that want to do away with shipping weights are wanting fiberglass and carbon fiber parts so that they can lighten up their combos and making it "fair" to their heavy combos that can't compete with the light combos?
If this passes, it WILL be the beginning of "E.T. 2 to the lanes"!
(1) You can only have 100lbs of loose ballast including weight box, if your attaching more than 400lbs to the frame you should be in a upper class. (2) You can ask for fiberglass hoods and doors with or without shipping weights and I’m sure the answer is going to be a No. Modified, FGT and GT have no shipping weights and bracket 2 has not been called to the lanes. I had the same fears as others when the did away with shipping weights in GT, nothing has changed just made more guys happy.
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 02-13-2022, 05:12 PM   #3
Charley Downing
Liked 653 Times in 89 Posts
Billy its not 1975 anymore. Eliminating shipping weights is way different then asking for carbon fiber hoods and doors. I agree let tech get hard on a ballast max weight, make sure that racers are following the 100 total lbs weight box rule. Just enforce the current weight rules. But at the end of the day its has to be easier in NHRA and the racer for this class to make it. The days of 15 plus NHRA tech guys that an event know the STK/SS rules front and back are over and never coming back.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 02-13-2022, 06:47 PM   #4
Bill Grubbs
Liked 569 Times in 67 Posts
and made others unhappy.
If you want no shipping weights then run the superstock classes of Modified, FGT and GT. Leave the rest of Stock and Superstock alone!
Quit all the rule changes...and the proposed rule changes!
If you don't like the rules then run the local associations and change their rules. Heck, Charlie, you have the power to change the GLSSA rules.
Bill Grubbs is offline   Reply With Quote
Old 02-13-2022, 03:46 PM   #5
SS/GSI
SS/GSI's Avatar
Liked 759 Times in 109 Posts
Thumbs up Re: Shipping weights
Originally Posted by Charley Downing View Post
Can someone explain to me why we need shipping weights for Stock and Superstock anymore? I would love to hear one good reason. I mean a combo can already move up or down one class from its natural class. If someone can get extra weight out of a car/combo why should they be forced to run a heavier class. Or here is a though just rewrite the current rule to make it where you can move up or down 2 class's higher or lower then your natural class. you people are making this way harder then it needs to be.
I mean no shipping weights for cars in SS/GT appear to be working with no issues. Why not just eliminate factory shipping weights all together?
I mean its pretty simple take your (NHRA HP) x (that class weight) plus 170lbs and that's your min for that class. Pretty simple
I can’t see people adding 200-400 lbs to make their cars slower. I believe this was brought up a few weeks ago to the SRAC committee and Kent Hanley and Mike Crutchfield were the major reasons this was shot down. Which is funny because they both compete in a SS class where factory shipping weight are not used.
Charlie, at this point seeing how NHRA has and will most certainly continue to handle the situation moving forward, I believe that you are on the right path, in all seriousness. The following should be put in place for 2023 season.
1. Get rid of ALL shipping weights...if you can fit between the max and min for the class your in!
2. Get rid of all 1/2 lbs weight breaks and make ALL classes 1# weight breaks. More cars per class, more chances of heads ups and less classes to manage for NHRA. Perhaps this might entice manufacturers to come back to sponsor class runoffs? If not, at least it will minimize the mathematics for all involved.
3. Combine stick and auto. Automatic transmissions and convertor technology has come along ways in the last two decades. This again would streamline our classes and allow for more heads ups and less for NHRA to manage. It seems to be working in the FS, FSS and FGT classes.
If we are going to use forward thinking to resolve issues within the organization, then mean it...LOOK FORWARD!!! not just in the now. Rip this whole deal off like a Band-Aid, give everyone this season to make the necessary adjustments and there will be no more arguments...well other than AHFS but that's another thread! LOL
Kevin Gaffney
1123 SS/GA
SS/GSI is offline   Reply With Quote
Old 02-13-2022, 03:50 PM   #6
GUMP
There has to be a maximum weight for every combination to keep racers from doing silly things....
Daren Poole-Adams
NHRA Stock/SS 2007
Old 02-13-2022, 04:20 PM   #7
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
And a minimum too.
Old 02-13-2022, 06:58 PM   #8
Billy Nees
Liked 7,887 Times in 1,753 Posts
1. Knock yourself out if you want it in SS. SS needs more SS/GT/Comp cars.
2. Sounds good to me in Stock and SS. BUT it should probably be put to a vote. A real vote. Too many Racers will be affected to not. With 1 lb. classes, the higher classes in Stock would be a real bloodbath.
3.This sounds good to me too. It should have been done when NHRA instituted the AHFS.
Oh, wait a minute, you apparently have issues with the AHFS too! Are you one of those WOKE people?
Billy Nees 1188 STK, SS
