Old 02-09-2022, 10:00 PM   #1
GTS340
Liked 1,361 Times in 416 Posts
Default Re: Access to AMA Shipping Weights?
Any bets this all goes away.
Paul
Old 02-09-2022, 10:14 PM   #2
MANSRACING
Liked 10 Times in 4 Posts
This should have never even started in the first place.Just keep it up and there won’t be any Stock/ SuperStock.
Randy
MANSRACING is offline   Reply With Quote
Old 02-09-2022, 10:47 PM   #3
J.R. Haddad
Liked 1,471 Times in 308 Posts
Thumbs down Re: Access to AMA Shipping Weights?
So Kevin, you didn't accomplish what you wanted with the Firebirds,
so you you took one more shot at the 2015 Camaro on the way out??
What are you doing for an encore?
J.R.
J.R. Haddad is offline   Reply With Quote
Old 02-09-2022, 11:18 PM   #4
SS/GSI
SS/GSI's Avatar
Liked 759 Times in 109 Posts
What are doing for an encore?
J.R.
J.R., I simply used the 2015 as an example of the "entire" guide NOT being properly revised...the 2015 376ci Camaro is a factory street version car, not a "paper" car(COPO, Dragpak, CJ), yet it still was not corrected by NHRA.
Kevin Gaffney
1123 SS/GA
SS/GSI is offline   Reply With Quote
Old 02-10-2022, 12:42 AM   #5
J.R. Haddad
There are other examples of the same formula, which was started by
Dodge, and approved by NHRA, and I appreciate trying to gets things
straightened out, but these weights have been around for 30, 40, 50
years or more. Now we have NHRA upset that we're upset, some
combo's completely removed, and for what? I will work hard when I
can advance myself, not when I only break even, and all my peers
get hurt.
J.R.
Old 02-10-2022, 08:45 AM   #6
james schaechter
Liked 1,443 Times in 302 Posts
Clearly a lot to unpack on this issue, but this example and a few others are great examples of how some combos just got lucky depending on how you view it.
I would expect anyone running a Pontiac GTO with a LS would appreciate the weight loss that the Camaro got somehow.
I think now that the shock and awe has hit over this topic there will have to be some process that works and makes sense, even if it is a shipping weight with a plus or minus variance of some sort.
Clearly ,there were decades of deals made here rather than a process that could be understood by all.
Hopefully some good comes out of this transparency. So many say and I agree that one of the key responsibilities of a sanctioning body is to apply rules in a clear and consistent manner.
At least this is an attempt to apply process.
James Schaechter 3163 STK
Old 02-10-2022, 09:15 PM   #7
Frank Bialas
Frank Bialas's Avatar
Liked 24 Times in 14 Posts
Originally Posted by gts340 View Post
any bets this all goes away.
Paul
bingo
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
