Old 01-30-2022, 12:35 PM   #34
Carguy49
Liked 2,925 Times in 702 Posts
Default Re: Never to early to think about Indy and AHFS
"It’s funny that you bring up the “challenge” of bringing one of Billy’s combinations “into 2022.” I’m currently in the process of redoing the engine in the 6 cylinder nova. I pretty much have been doing everything that I have been told as far as using more modern parts. This includes a more modern lobe style cam, rocker and spring combo, and a different ring package. The pistons I left alone being that they are very good quality to begin with, and I’m not sure an aftermarket rod will help a sub 6,500rpm motor. Going to try a good 3 speed as well over the powerglide. The things I have changed have all helped make the higher horsepower cars as fast as they are today. Time will tell if the 6 cylinder will appreciate such parts."
Doug, what was your best time with the old combo and where do you hope to be when it gets back to the track? Just curious and good luck with your project.
Ron McDowell - Did Race
