Old 01-30-2022, 11:51 AM   #1
Doug Hoven
Liked 855 Times in 164 Posts
Default Re: Never to early to think about Indy and AHFS
Originally Posted by B Parker View Post
Doug I'm glad to see your taking on this project. It will be interesting to see how much you pick the car up. My thought with the aftermarket rods wasn't so much as the strength but to be able to play with rotating weight. I would think the quicker you can get that car moving the faster you will go. I have a good spare metric, but I use a 350 spline. You should take advantage of a metric converter. Let us all know how you make out. Thanks Barry
I understand completely with the rotating weight. One of the changes I’m making was the ring package I put together which cut ALOT of ring tension out of the equation. The hope is to cut some drag out and allow the engine to spin up with less effort. Unfortunately a new converter for the metric is not really in the budget at this time, but we were able to piece together a glide input setup. With this I can use the same converter in the car as well as the other experimental 6 cylinder converters Billy has tried over the years.
1189 F/SA
Defunzalo Racing Enterprises
Old 01-30-2022, 12:11 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Not sure about Chevys but the aftermarket rods for a 383-440 weigh more than the stock ones and (legal) replacement pistons for BBM are still 900 + grams with pins.
Paul Precht is online now   Reply With Quote
Old 01-30-2022, 12:35 PM   #3
Carguy49
Liked 2,948 Times in 709 Posts
"It’s funny that you bring up the “challenge” of bringing one of Billy’s combinations “into 2022.” I’m currently in the process of redoing the engine in the 6 cylinder nova. I pretty much have been doing everything that I have been told as far as using more modern parts. This includes a more modern lobe style cam, rocker and spring combo, and a different ring package. The pistons I left alone being that they are very good quality to begin with, and I’m not sure an aftermarket rod will help a sub 6,500rpm motor. Going to try a good 3 speed as well over the powerglide. The things I have changed have all helped make the higher horsepower cars as fast as they are today. Time will tell if the 6 cylinder will appreciate such parts."
Doug, what was your best time with the old combo and where do you hope to be when it gets back to the track? Just curious and good luck with your project.
Ron McDowell - Did Race
Old 01-30-2022, 02:24 PM   #4
Doug Hoven
The fastest I went was on a sub 50 degree day at Atco in November. I went a 14.35 at about 90mph. The fastest I went during the season was .20 under at Cecil for the division race. I’m not really sure what to expect when it goes back together. The engine had not been apart since 2001, so it’s safe to say even just a fresh rebuild would pick the car up a decent amount. I also utilized the “automatic help for slugs” as previously named in this thread and got a few hp off the combo. It didn’t seem fair to have an inline 6 with a 200 cfm carb to be rated the same as v6s with better heads and means of induction. The loss of weight will definitely help some.
1189 F/SA
