Old 01-20-2022, 12:47 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: C-11
Atco's fuel prices were very high for the last few years.....
$100 for 5 gals of any high octane VP or Sunoco when they had it.
Much cheaper buying from better sources and larger amounts....
C-11 was $1 more than C-12 the last time I was running either fuel....and for me made very little difference..
The hard part is getting it and transporting it in drums, always has been but it saves a lot of money.
Rich Biebel
S/C 1479
Stock 147R
Old 01-20-2022, 09:59 AM   #2
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: C-11
Time to have no fuel checks in Stock. Run pump gas in your low compression stocker.
Steve Teeter STK/SS 620
SDT1DYI is offline   Reply With Quote
Old 01-20-2022, 10:08 AM   #3
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Default Re: C-11
That's not gonna happen, and it shouldn't. We just had this thread a while back. While some would run a cheap pump gas, others would be back to exotic mixtures to get every ounce of hp possible, which I would probably take advantage of also. Fuel check is to keep the playing field level. If you want a cheaper fuel, run Sunoco blue. It's close to half the price of some VP fuels.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 01-20-2022, 11:14 AM   #4
Ryan Horensky
Liked 109 Times in 18 Posts
Default Re: C-11
I’d switch to Sunoco if we could run Surge. Not on the approved fuel list though….
Ryan Horensky is offline   Reply With Quote
Old 01-20-2022, 12:11 PM   #5
1347
1347's Avatar
Default Re: C-11
As you know Ryan, I had good luck with the surge, we need to follow up with Sunoco and NHRA and get it back on the list.
Duane Hoven
1342 SS/GT
Old 01-20-2022, 12:24 PM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Default Re: C-11
Was Surge better than sunoco blue ?
Old 01-20-2022, 12:27 PM   #7
Ryan Horensky
Default Re: C-11
Definitely. Was confused why it was taken off the list in the first place. Our car ran pretty much the same with the surge as it did with C11.
Old 01-20-2022, 11:39 AM   #8
garyc
Liked 51 Times in 30 Posts
Default Re: C-11
hi,
I can run pump gas on the dyno?? mopar 400 8.1-1 comp. I have 2 pails of c-11 saving for march t/t
garyc is offline   Reply With Quote
