Liked 319 Times in 108 Posts
There is big difference between that 2barrel 305 cam and 4bbl 305 cam...
about 20 degrees difference... I'm not saying that cam is the best for a 2bbl 305 but I do know that it is about 20* short on duration for a 4bbl. 305 stocker.. lift with stock rockers and high spring pressure you have to add a little lift to get to spec but that may be a little too much for 357/390 $100.00 is a good deal though for someone it would work for.... give Bullet a call and they will grind you a brand new cam for your car... probably $200-250 range Mike Taylor 3601 |
#2 | |
Liked 54 Times in 33 Posts
