Liked 226 Times in 74 Posts
Whats the best coil spring compressor for Ford front suspension?
Liked 1,102 Times in 301 Posts
What style of Ford front suspension? For the unibody shock tower type, I always used the regular 4 hooked threaded compressor. What I did, was remove the front shocks, drop the compressor inside the spring from above, using a leaf spring U bolt on top of the tower for the compressors upper hooks to grab, and then used the screws nut to compress the coil enough so that I could unbolt the upper control arms inner shaft bolts, and swing the arm out of the way, and then release the tension on the spring, to remove it.
Liked 79 Times in 11 Posts
bob beals 7244 |
Liked 359 Times in 135 Posts
All of those are good unless you're working on a 64 Fairlane. They are a different animal. A real mean animal.
Who owns this car, with the peace sign,mag wheels, and four on the floor? |
for the record old springs are out of the car and im trying to get the new ones compressed enough to put them in. How does the Auto krafters one work for springs outside the car?
Liked 133 Times in 76 Posts
https://www.ebay.com/itm/26538118453...wAAOSw7p9hewZ4
This is the coil spring compressor I have, it's actually made by Branick. I'm a GM guy but a friend that restores old Fords borrows this every time he replaces coil springs and says it's the best he's ever used. |
Liked 350 Times in 134 Posts
The Branick spring compressor is, by far, the best one out there. IF you can find one.
I've never understood why they quit making them other than I would imagine there is a liability issue. |
Liked 237 Times in 126 Posts
On my 68 Mustang I use the common double hook type that don't fit down the shock towers on old Ford products. I pulled the pins from the lower set of hooks so they come off. I drop the compressor in from the top and slip the lower hooks in from the sides between the coils. I use cotter pins or short bolts to secure them. Then twist with a wrench to tighten. There are better specialized tools, but this works. For me...
Liked 917 Times in 257 Posts
I have good compressors, but on a recent Ford deal and drag race springs, I ended up leaving the ball joints hooked up and pulling the lower control arm bolts. Used a strap to control the spring and keep it from wanting to push the arm out. Floor jack it up into place.
Sounds hinky, but worked for me. They are not easy. Be careful with Chinese copies of good compressors. The metal isn't the same and these tall springs can cause them to fail at the worst time. |
